Is it necessary to use the plastic tube when installing Meth injection??
I am going to be running a 99 coolant tank that I modified with a stock level sensor and I want to know if using fuel/vacuum line from the tank to the pump is going to cause any issues. I'll probably stick with the plastic line from the pump to the nozzle due to the psi rating. Just wondering if it is safe to use a different hose for the tank-pump.
Only going to be running probably a 30/70 mix as I need it more for cooling due to the 10:1 pistons.
whats everyones thoughts???
