Hi guys,
I am trying to track down a vibration that seems to be getting worse. You can kind of feel it in the passenger seat, but it is mostly in the steering wheel. It occurs between about 45-65 mph.
I finally jacked up the car and found I need new carrier bearings and probably need to adjust the backlash at the rear diff. The most obvious cause of my problem, I think, was play at the rear passenger wheel. I can move it a fair amount (maybe 1/16-1/8" at the tire). It is vertical play, as in if I put a hand at the top and bottom of the tire and push and pull I get play. It looks to me like it moves until the rotor hits the brake pads.
I can't find play in any suspension parts, not even in the adjustable control arms.
Question: Does this sound like a bad wheel bearing?
Anything else to check before I replace? And does anyone have a part number for the assembly? Alot of the parts stores list the same number for turbo/na, which can't be right.
Thanks!
Ben
