Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: overheating problem
    94's have the gauge sensor and the fan sensor in the water housing.
    look and see if you have any sensors on the bottom of radiator. if you do then your are controlled by them if you dont have any sensors on bottom of the radiator then yours is moved.
    Im just curious could you go out and check??
    I do not have any sensors in my radiator. They were all moved in 94.
    Quote Originally Posted by whitedevilstealth View Post
    I blead the system last night and pressure tested it and it held 20psi in the cooling system. Maybe there was a huge bubble.
    has this problem gone away now?
    What coolant cap are you running? If stock, try running a 1.3 bar cap.
    13psi stant cap. Tested good to 14psi
    get a 1.3 bar cap and see if it overheats.
    Ok, I'll try that. Thanks.
