Went to pure tuning in toledo and was running good on the dyno. But it started overheating and blowing coolant out of the overflow tank. So i took it home and re torqued the head bolts and took it for a drive. It boosted really good and seemed to not be blowing coolant but after I got on it for a while then stopped, it started overheating gradually. What do you think the problem is? I put somestock heads on it after the old ones got screwed up from a valve breaking. I put MLS gaskets on it, torqued them in sequence and in increments up to 94 ft lbs. When I got back home I let it sit and it overheated again then shut it off and put some coolant in it and it took half the jug, wtf, I'm at my boiling point with this car and have dumped way too much money into it for it to just sit around. Help would be appreciated.
