1) Well could be, but my brakes worked totally fine before the conversion!
2) Sorta banned on there for a while, Plus no-one really knows anything on that website anyway
3) Actually AFAIK I'm the first!
4) It looks normal to me, but I will have the car on jackstands tomorrow and while it running get someone to press the brakes while I look at the caliper
5) Yes, always bleed in that order. Except when the new brakes when on the front I only bled the front. Rears were only done 500km's ago so no need to do all 4 again.
6) Again yes, My lines AFAIK are in good order. No signs of visual wear front or rear.
7) I doubt it, although anything is possible. if it was swelling under pressure, it wouldnt explain the master cylinder puking the fluid out.
Am I right in thinking I either need a bigger master cyl or one - or both - of these calipers need to be taken apart and inspected?
