Results 1 to 10 of 30
Thread: DIY AWS Delete from scratch!!!
    Never finishes any verified
    Feedback Score 8 (100%) DrGonzo's Avatar
    Wake Forest, NC
    Post DIY AWS Delete from scratch!!!
    While in the process of restoring my Stealth TT I wanted to delete the AWS. The lines were really corroded and leaking. I am crediting Drweldin as he gave good directions on another forum as to how to do this.
    After removing all of the AWS lines and pump from the rear frame I plugged the hole with a 1 9/16" Freeze plug. There are a few different types of freeze plugs. There are the metal ones that most people silicone in. I actually used an expandable plug as the freeze plug is just a little to small and the last thing I wanted to do was drop it into the read dif. The expandable plug seals and golds just great!
    As for the Heim joints, I order all of my parts from Speedway Motors:
    http://www.speedwaymotors.com/Produc...=heim&deptId=0
    Here is a list of parts needed:
    (2) Swedged steel tube: #910-34258-7 (7 inches long, 5/8" threads)
    (2) RH Rod Ends (1/2" holes): #175-0126
    (2) LH Rod Ends (1/2" holes): #175-0326
    (2) RH Chrome Jamb Nuts: #910-01006
    (2) LH Chrome Jamb Nuts: #910-01106
    (1) Aluminum spacers for rod ends (pk of 8): #546-4108
    All parts came to like $94.0 shipped and they are top quality parts!
    I reused the factory mounting points. Since the joint ends are 1/2 holes I used a 1/2 bolt on the control arm side as it is a straight hole to mount the joints too. No need for drilling or tapping out holes. The x-member side is a tapped 12mm hole. I used a 12mm grade 8 bolt to mount it on the x-member side. the 12mm bolt is a hair to small for the 1/2 joint hole. Once you use the aluminum washers and tighten it down there is no play in the joint whatsoever.
    Now you will need to plug the front steering lines. The threads are BSP not NPT. You can order BSP plugs online but I have heard good things about people using NPT plugs and Teflon tape without having issues. Plugs are 1/4 in memory serves me correctly. I actually swapped out the front steering rack to an N/A rack. The only difference in the racks is the lack of rear steering lines and the N/A rack is geared differently so turning should be nice and crisp.
    Weight savings with everything removed is about 30lbs.
    Let me know if anyone have any questions!
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
  2. The Following 3 Users Say Thank You to DrGonzo For This Useful Post:
  3. #2
    Forum User verified Feedback Score 0
    Iowa
    nice write up! i really really need to do this to my car. when im taking a clover leaf off ramp the rear end feels really loose. i have no need for the aws and i could use the weight reduction!
  4. #3
    Forum User Feedback Score 1 (100%) sbrunthaler's Avatar
    Berlin, Germany, Europe
    The link to speedway motors does not work, sorry.
  5. #4
    Wake Forest, NC
    Oops.... Link fixed
    TD04 Upgrade & Billet TD05 Upgrades Feedback Score 8 (100%) 92RT-TT's Avatar
    Hudson, WI
    nice writeup. If I build up another Vr4 I'll be deleting the rear steer that for sure!
    What it is? Not Verified Feedback Score 0 ViperZ's Avatar
    Awesome, thanks for all the part numbers, I'm just getting ready to delete the AWS!
  8. #7
    Forum User Feedback Score 13 (100%) Austin@STM's Avatar
    Yup same thing as all the "kits" out there for a lot less $$$, thats how i did mine.
    -Austin@STM
    And the list goes on...
  9. #8
    Wake Forest, NC
    The GTO MR doesn't use heim joints.
    None of them do!
    You use the Heim joints to lock the rear end straight after removing the rear steering. Or did I miss understand what you where saying?
  10. #9
    -BOOSTTD- verified Feedback Score 2 (100%) mh3kgt's Avatar
    Elko, Nevada, United States
    Thanks for the writeup man! I'll refer back to this if I ever decide to remove the AWS
  11. #10
    LW fears my posts Not Verified Feedback Score 1 (100%)
    Dallas TX
    You're using a FWD rack? How many turns does it have lock to lock vs the TT rack?
