Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: DIY AWS Delete from scratch!!!
    Stress free wheel gap. Not Verified
    Jan 2011
    Morrisville, NC
    Ah okay. My SL didn't have any nifty features, just a broken ECS... Now I got a VR4 with all the working bells and whistles, so I am hesitant to start deleting all of them. I still have my stock cat-back on for the active exhaust, even though my catless turboback doesn't seem to get muffled in tour mode at all
    I'll give it 2 weeks before I end up replacing my suspension once the ECS goes out, the rear spoiler when the active aero get stuck in the upright position, and my cat-back exhaust when it develops a leak.
    Never finishes any verified
    Wake Forest, NC
    Once the MOD bug bites you will always have that itch...LOL
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
    -BOOSTTD- verified
    Elko, Nevada, United States
    I think I'm beginning to like deleting stuff as much as adding new mods
  4. #24
    ~2006
    Pittsburgh, PA/Wheeling, WV
    Do you happen to have the length of the bolt you need? I am ordering everything on that list, but that doesn't include the bolts, correct? Would I be better off ordering a 1/2" bolt since that is the actual size of the hole (instead of metric)? Then just need nuts and I'm ready to rock?
    Just want to make sure, I'm stock piling parts to powdercoat the rear end, bushings, new suspension, AWS delete, control arms, etc. and want to have it all ready when I tear it down!
  5. #25
    iowa
    pretty easy to do mod , i have done prolly about 8 of em now . all done in acouple hours in my garage with just a floor jack. well worth it imo .
  6. #26
    New Member Not Verified
    Philly area
    Less weight (30 lb reduction)
    Less "stuff" to break
    Not really needed - the 96 Stealth TT didn't come with it
    Only functions over ?35? mph and some road racers/autocrossers find it more predictable to remove it
    My case. Was leaking badly. Always wanted to remove, so this was a good excuse to do it. Stick may be ultimately no different, but vehicle rotation in curves at speed is much, much better. And that would be expected given how the RWS is supposed to work. Love what it has done for response to steering wheel movements.
  7. #27
    Advanced Tech? verified
    Quote Originally Posted by nodoze View Post
    do you need two jacks to raise it up or does it balance with just one jack on the diff?
  8. #28
    ~2006
    Really? Didn't have problems with stuck hardware/etc.? Did you remove the hardlines running to the front (forget if they are bolted down or not). I am putting on coilovers/control arms/tie rod ends/sway links and would like to do this at the same time so I only need one alignment, but this is my only car so if it is down for a while I am screwed.
  9. #29
    West MI
    It balances perfectly on a standard 2-3ton jack head. Problem is most jacks are not long enough to get under the car to the diff. My jack is 40" long and works like a dream, I wheeled the whole assembly around my garage without a worry. Set a few 2x4's under the lower control arms and lower the jack, good to go.
    92 3000GT VR4
    Matt
  10. #30
    West MI
    even my $60 harbor freight jack had no problem using a 2x4 for extra height.. was able to balance the sub frame by myself for removal and re-installation.
  • History
  • Information
  • Groups
  • Events
  • Resources
