noo.... Not through the water or oil passages, just past the rings and down to the crankcase. If it were going through your water passages and oil passages in the block you'd have a head gasket issue.
so if it's pressurising the crank case...how is this pressure transferring back up into the heads if not though the coolant and oil passages?
1996 GTO, Owner since 2003.
Well no, you're right. It makes its way up to the heads because the pressure obviously equalizes throughout the engine, but the water passages are sealed and should not be affected by crankcase pressure.
Cool cool, not trying to proove anything here...just understand itthanks for the info!
I wonder if that explains why the oil drains from play engine (a spun bearing 6g74) were coked up...maybe the blow by was creating some sort of substance that over time blocked them up!
I'm convinced that this 74 spun the bearing due to it pumping all the oil into the heads and starving.
A very common occurance. Usually it occurs due to some stupid additive being poured in the engine. Water vapor and heat most likely cause massive amounts of sludge though. Clogged all the returns and just starved the crank, like you said.
06 Mazda6s - Gone
02 Subaru Impreza WRX - Sold
95 Subaru Impreza USDM WRX engine JDM STi exterior swap - Sold
05 Dodge SRT-4 - Sold
94 Dodge Stealth RT turbo - 99 front end, 13G's with supporting bolt ons
FS: 1)Spec stage5 clutch kit $150 shipped 2)Stealth RT LED taillights $80 shipped 3)Stealth pearl yellow OEM 17's with tires 4)RARE Defi narrowband airfuel gauge $70 shipped 5)DNP Y-pipe with Blitz DD BOV $220 shipped
In a nutshell, yes.
yep that setup works fine, you can squeeze a catchcan just to the left and down from the fuse box if you want:
see that little blue scratche up spot between the fuse box and the filter:
i took a look under the fusebox and there is actually a lot of room. but the can i got is too big to mount there. just finished the install. thanks guys for all the tips!
