Results 1 to 10 of 10
Thread: PO403 - EGR solenoid
    Cazenovia, NY
    Does anyone know what the differences are between the 94-95 EGR solenoids and 96+? Obviously, the 94-95 solenoids have only 2 ports on them, whereas the 96+ have 3 ports. I believe that my 97 actually has a 94-95 solenoid, because it only has 2 ports on it. Of course, I get a CEL for a faulty solenoid.
    Subscribed... I just deleted the egr on my 97 vr4 and am getting the same CEL. Do you know of any tricks that might make this go away? I have played with running the vacuum lines in different configurations but it also throws the code eventually. I tried following oohnoo's method but it didn't work for me.
    Thanks, John
    Cazenovia, NY
    There's no way around it. You'll need to put it back in. My issue is that my solenoid appears to be from a hybrid car, and I don't know if they are compatible.
    SoSoCal verified Feedback Score 1 (100%) DuTTch's Avatar
    I hated all those check engine lights , thats why I went 95 ecu lol, all gone. Its like a miracle. I have a a 95 and 96 solenoids (the same I beleive), complete sets. PM hydedw on 3si he found out some interesting stuff on the differences on the 97
    Cazenovia, NY
    I use a 95 ECU for everything too.... except inspection
    Sorry I have done any research yet... but how hard is it to switch over to a 95 ecu?
    Thanks, John
    plug and play
    Cazenovia, NY
    Quote Originally Posted by DuTTch View Post
    plug and play
    Not completely. Almost plug and play by like, 8 pins. The car WILL start with no modification though.
    Quote Originally Posted by x2xtreme360 View Post
    There was never any modifications made to my harnass and it ran just fine.
    Cazenovia, NY
    Yea, it runs fine with no modification. There are a few pin differences between the 94-95 and 96+ ECU's though.
    The engine load pin, turbo meter, O2 heaters, and a few others.
