Results 11 to 20 of 27
Thread: Review: K sport 8 piston 355mm big brake kit (front only)
    yeah, there is honestly no reason to go Drilled at all, all the faces I'm interested in are some variety of slotted or blank!! The ABS is fine, essentially it does nothing until it senses a wheel has stopped rotating and then reduces the braking force to that wheel...still ran fine on my Ksports.
    1996 GTO, Owner since 2003.
    Roo fuckers anonymous verified
    Perth, Australia
    Nothing wrong with slotted rotors people. Nice write-up Mikey.
    Scotty
    Australia verified
    Melbourne, Australia
    I guess you could deactivate the ABS if there were issues.
    I guess, but ABS has been designed to work with pretty much anything that's thrown at it.
    http://www.aboveallmotorwerks.com/Pr...SCTYPE996.aspx
    http://www.aboveallmotorwerks.com/Pr...996-01-05.aspx
    Kit Specifications:
    * Rotor Size: 380X34mm - 2-PIECE
    * Caliper: Style:FC12 - 12 Piston
    * Axle: F
    * Wheel Fitment: A: 37, B: 220, C: 138
    * Click Here for Wheel Clearance Chart
    * Kits usually require these minimum wheel diameters:
    o 330mm rotor (13 inches) - 17 inch wheel
    o 355mm rotor (14 inches) - 18 inch wheel
    o 380mm rotor (15 inches) - 19 inch wheel
    We have INFO on fitment thank god!
    I'll next go measure my current brakes + cut a fitment card
    Twin Turbo verified
    had this thought yesterday. How the hell can I tell if 360mm rotors will fit under my wheels. There must be some sort of diagram that can be cut out and tested......
    Waiting install
    Build Thread
    very nice. i've still got a boner for some d2's. i lack funds.
  8. #18
    whats the biggest rotor you can put on oem brakes mike?
    See no EVO, hear no EVO, FEAR NO EVO!
  9. #19
    for 2g's, i was under the impression it was around 330mm. on the fronts.
  10. #20
    not far from breaking down
    wait, are there any point to running larger rotors because the pads will be still in contact with the same surface area, only difference being the discs will have more material thus lower temperatures. Also can you actualy run 330mm on the 2nd gen brakes and if so where would you get them??
