Results 1 to 10 of 22
Thread: Steel bushings for adjustable control arms?
    Forum User verified Feedback Score 2 (100%)
    St.Louis
    Does anyone know where to get the correct size steel bushings for the rear camber and toe arms? Mine squeak so bad, and Ive tried every sort of lube/ grease i can think of. I replace the lube about once every two weeks and this is just getting old.
    Forum User Feedback Score 0
    April 2010
    Waukesha/Menasha
    you can get poly bushings on 3sx
    Forum User Feedback Score 0 Stealth_E's Avatar
    It likely isn't the bushing squeaking, but the actual rod end itself. Mine are getting pretty bad and I'll likely be replacing them with the teflon ends to see if they stay quiet a bit longer.
    Forum User supporter Feedback Score 0
    I bought a set of the Maximal arms a while back. Overall the quality was good. However I could not make myself use the supplied aluminum bushings and 1/2" bolts. The oem bolts are 14mm if I remember correctly. I didn't like the aluminum and was not about to stick a 1/2" (12mm) bolt in a 14mm hole on something as critical as suspension. It looked like it was just asking to damage the holes in the frame over time to me.
    I took one of the aluminum bushings and the factory bolt to a local machine shop. It ended up costing me around $20 to have all 4 steel bushings turned with the correct sized center hole to accept the factory bolt. My rear suspension is tight and I haven't heard the first squeak yet.
    Check around and see what you local machine shops would charge to make these. The guy I used to make mine is very reasonably and does good work. The only problem is that he is kind of off the grid. If enough of you guys need these bushings I'll take a trip out to the country and get a batch of these things made up.
    Forum User Feedback Score 2 (100%) Maximal's Avatar
    Avoca, NY
    Quote Originally Posted by Bloodlust182 View Post
    This is what you'll need: Suspension - Heavy Duty Adjustable Control Arm Rod Ends - Maximal Performance
    The standard rod ends work for some people (I've had mine for years with no squeaks) and others have issues. Greasing them helps sometimes but the only sure-fire way to resolve it is the with HD teflon lined rod ends.
    Quote Originally Posted by Need_a_Miracle View Post
    That 1/2" bolts are rated to more than enough to be fine but I understand you wanting piece of mind.
    St.Louis
    By teflon coated does that mean the ball inside the loop is coated in teflon? i guess thats the next thing on my list to get then.
    BAD ASS - I've got one Not Verified Feedback Score 9 (100%) j2k4's Avatar
    I'll be mounting mine (with the teflon ends) next week - I'll try to remember to report the results here.
    Terry-
    Are you selling a lot of the teflon version?
    Keeping it real... Feedback Score 0 ChargerX3's Avatar
    Oct. 2006
    Reno, NV
    You guys should think about putting a boot on as well.
  9. The Following User Says Thank You to ChargerX3 For This Useful Post:
  10. #9
    So these teflon ends are sealed and self-lubricating, right? No prep before install or maintenance at all? I just ordered a set, but I'm considering a boot as well for added assurance of silence.
  11. #10
    Quote Originally Posted by Stealth_E View Post
    I ordered some - they sent the wrong size.
