Results 1 to 10 of 16
Thread: Third time is the charm? DSM going for 10s (on friday)
    11 sec FWD! (old name: 94atxvr2) Feedback Score 0 11secondFWD's Avatar
    2004 ****Click my home page for videos*****
    Toledo OH
    Well I just bought MT ET Drag slicks 24.5x8x15 (17lbs) and jegs sport star aluminum rims (18lbs). My street wheel tire combo was 42 lbs, so over all I will save 7 lbs a corner and 28lbs total of rotating weight.
    Plus I am sure I will be able to launch at much more boost. I only could launch at about 12psi with street tires and in the previous threads you car see and hear the traction loss. I was only getting 1.65 60ft which is not very good. Many 14b and 16g autos run low 1.4s consistently on dot slicks. SO if I leave at 25+psi I plan to cut a 1.4 or so and cut at least a few tenths off of my 11.08 time. Plus I can let a good amount of air out of the tires if I have any traction problems. But a local that runs 8.60s @171 and had a 1.2 60ft ran those times on the same slicks so I assume I wont have a problem with the lowly 10s.
    SO with less rotating weight and a ton of traction I am hoping for 10.80 or so.
    Lastly, IF I don't succeed or want to improve I am going to put some methanol in my fuel cell. I have 1150cc injectors. I am at 80%IDC with them on e85. 1150s are roughly 770s (gas) with e85. SO if I run 33% methanol and 66% e85 my stoich ratio would be 8.466, which would make the injectors roughly 660s. I would have to add roughly 11% more fuel to my tune. I think the IDC will still be under 100% and okay, especially if I am running leaner (less rich) than what people do on gas and I can always bump my fuel pressure up since I have enough pump (2 inline walbro 255hp). I expect it to give me a decent increase in power. I plan to put 1gal of methanol in with 2 gal of e85 to make the mixture. I do not think it will be a problem because it is not straight methanol (only 33%) so it shouldn't be as corrosive. All of my fittings and rail is methanol compatible (anodized). And I will be running e85 through it on the way home to flush it out.
    But if I hit 10s on just e85 I will without a doubt be kicked for no roll cage. SO I wont need to do the methanol and wont get to run anymore. So I will need a roll cage soon no doubt.
    But wish me luck. If I do not get 10s now, I am going to be pretty disappointed. I am planning to start racing 4pm friday april 15th (my birthday), and will post up all the stuff later that night. I hope you all enjoy the media.
    Forum User Feedback Score 0 19Eclipse90's Avatar
    Sep 2004
    OKC
    In for results. Best of luck to you!
    -Brian
    Taichung, Taiwan
    Good luck, looking forward to you finally breaking it. (by it I mean 10's)
    Toledo OH
    Well I just changed the engine oil, oil filter, Auto tranny fluid, tcase oil, rear end oil, spark plugs. I picked up 17 gallons of e85. My slicks arrive in the morning. They are mounted and balanced and I have open lugs. I am ready to go get 10s. Just got to test fit slicks, pack up, tech in and race.
    Forum User Not Verified Feedback Score 1 (100%)
    Dec 2010
    Good luck dude! Sounds like you got your ducks in a row!
    1993 Dodge Stealth RT/TT - For mod list, visit stealthTT.com.
    Driving Vicki Crazy
    Ninja Powers sent your way!
    -Chris
    Feedback Score 6 (100%)
    good luck!
    RTBOOST verified Feedback Score 11 (100%) Street_Chally73's Avatar
    Florence, Wisconsin
    Goed leuk!!
    Canaan NH
    Good luck man you will get it this time
    DR-750 club Not Verified Feedback Score 1 (100%) FeaRpb's Avatar
    Good luck out there.
