Results 1 to 10 of 12
Thread: questions for any statistics people
    I have a question on a worksheet i just can't wrap my head around. We've moved on past confidence intervals and what not so now i can't remember how to do it .
    Can anybody look at this question and help me figure it out. Can give me the answer if you want but i'd prefer a description of how you got to said answer .
    I'm probably over analyzing it
    Thanks guys.
    damn, it's been like...13 years since i took statistics. i got lost somewhere around chi square. i usedtacould be able to do that problem.
    p.s.
    am i correct in thinking that the standard deviation is .1 micrometers?
    ok wait, i'm not familiar with my greek symbology from statistics. .5 would be standard deviation. so the question is, in a sample size of 250...how many would fall outside of that .5 milimeters (which would be 10x the acceptable deviation--per manufacturer direction).
    is that correct?
    Shit. Three years ago I could have solved this more than likely. I was quite good at managerial statistics when I took it. Don't recall much of it anymore.
    sorry i was at a work meeting.
    The standard deviation is .5mm
    The question wants to know what the max confidence interval is as far as i read it.
    The thing that i'm confused on it says not to exceed 250 for sample size but does that mean can use less than 250.
    Sep 2004
    OKC
    I'm like the rest of everyone here, it's been a while since I've touched this stuff and I don't reckon I was terrific with it to begin, but here's my go at it. Don't take it for truth because I could very well be wrong; it makes sense to me.
    The mean isn't 0.05mm. The mean is unknown and, as far as I can tell, not needed. The +/- 0.05mm is equal to +/- [Z_alpha/2*(sigma/sqrt(n))]. Sigma is given as 0.5, and you know the sample size, n, as 250. Thus you can solve for Z_alpha/2 -- I calculate ~1.58. From the z-table, you find 0.9429 -- 94.29% as your level of confidence. This also means that alpha/2 is 0.571 (from 1-.9429) and it follows that alpha is 0.1142. Calculate your confidence interval 100(1-0.1142)% and you obtain ~88.58%. This checks out because I obtained a confidence interval of ~88.25% initially using linear interpolation. For reference as to what I interpolated over (this stuff seems pretty standard), a confidence interval of 80% has a Z_alpha/2 value of 1.2816; 90%, 1.6449; 95%, 1.9600; 96%, 2.0537; 98%, 2.3263; 99%, 2.5758.
    What it means, as far as I understand it, is that you are 94.29% sure (statistically speaking) that 88.25% of the sample measurements will fall under management's specifications.
    Good luck, and do let me know if I'm wrong!
    -Brian
    well i turn it in tmrw morning and am supposed to have it back when i leave school at 5pm so will post up the answer.. It looks right after reading through that though.... i've just been focusing on Ho and ha
    well it's official i don't like my stats teacher.. she just put an X through it.. but gave me 1/2 credit. But no notes on what needed to be changed . There was a couple questions like that.
    Sep 2004
    OKC
    So I was wrong? Bugger....
    not completely.. may have given to much info and that's why got partial credit i don't know.. irritated didn't actually show me where i got things wrong on some of the questions so i can study for the test.
