Results 1 to 9 of 9
Thread: What is the normal OIL Pressure on 91 ES
    Forum User Feedback Score 0 DarK_sTyLe's Avatar
    Jan 2011
    What is the normal OIL Pressure on 91 ES?
    Ft. Lauderdale, FL
    11.4 psi or greater at curb idle speed with oil temp 167-194F using proper oil weight.
  3. The Following User Says Thank You to RL7 For This Useful Post:
  4. #3
    Driving Vicki Crazy
    Your oil weight, RPM, coolant temp (oil temp) all play a role in oil pressure. What PSI are you getting, how are you testing it, and what are the other parameters?
    -Chris
  5. #4
    Jan 2011
    -Chris
    well am getting low oil pressure on the stock gauge,,, am running 5w-30 with the RPMS set to normal (750 + -)
  6. #5
    I'm Kind Of A Big Deal Feedback Score 8 (100%) Emilie@GZP's Avatar
    low oil pressure on the stock gauge, at idle, is normal, as long as it's not buried at the bottom.
    General rule of thumb, if it's about 2-3 ticks above the bottom big tick (towards the middle of the gauge), at cruising ~2-3k rpm's when warm, you are fine.
    Current:
    2004 ML500 - Mommy Mobile
    1995 3000GT VR-4 - lawn gnome
    1999 3000GT SL - 7,436 miles
    FOR SALE:
  7. #6
    Driving Vicki Crazy
    Quote Originally Posted by DarK_sTyLe View Post
    What is "low"?
    Is this when it is warmed up?
    Does it go up as rpms go up? What does it go up to versus RPM?
    -Chris
  8. #7
    Jan 2011
    What is "low"?
    -Chris
    when the car is cold the temperature gauge is center half way between low and high as the car gets temperature the gauge tick goes down if i rev to 2k rpm it goes up but it doesnt stay
  9. #8
    I don't trust the factory gauge mine is usually at 1/4 of the way and sometimes it goes 1/2 but never higher.
  10. #9
    Driving Vicki Crazy
    Don't trust an old sender with the old loose dirty slip on connector. Test with an oil pressure tester. But it sounds like it is where it should be.
    -Chris
