Results 1 to 7 of 7
Thread: Anyone know how to setup your AEM EMS antilag???
    Pueblo, CO
    i want to get this anti lag set up so i can use it to launch. anyone know how to set it up or have a setup I can test?? I read the manual but not really sure
    here is what are currently on my car. I dont even think its on? if i hold the gas down it doesnt spool...Are these setting correct? this was setup up from a previous tuner...
    Riding topless!! verified
    Owned 8 3s since 2005.
    Corpus Christi
    What is the benefit of this versus 2 step?
    Antilag spools the turbos without the car having to be under load. People use this in conjuction with the 2 step to have spooled turbos before/during a launch.
  4. The Following User Says Thank You to Frostedbutts For This Useful Post:
  5. #4
    Banned J. Fast's Avatar
    Very good Trev!
    You know how I feel Mike. I don't think you should do it.
  6. #5
    ~2006
    Pittsburgh, PA/Wheeling, WV
    Like they said I wouldn't use it unless your putting down some money or something.
    On my eManage setup I have it cutting ignition at like 3,500 RPM and it builds a few pounds. I would assume you could do the same. Cutting the ignition (opposed to retarding it) should be a lot better, but I still wouldn't sit on it/use it constantly.
  7. #6
    can't you just setup the 2 step without the anti-lag and not do damage?
  8. #7
    I'll agree with Jer, the ALS system is not one to be taken lightly. It does build a tremendous amount of heat. It does work, works really well actually. Just to give ya an idea, it spooled a GT42 up to 9 psi in a matter of 1 second. The 2 step comes on, then the ALS will engage. It's great for launch control. The NLTS-ALS is a whole 'nother ball of wax.
    For reference, this was the first time I tried it.
  • History
  • Information
  • Groups
  • Events
  • Resources
