Yeah,
I cant tap it on top of the assembly because of the fuel tank placement, however I did follow the wire from the mfi to my back seat then to right above the fuel tank so Iam thinking it was the same wire. I tested voltage at the MFI and then at right above the fuel tank and it was the same. I may have really screwed up though, its possible it wasnt the same wire. Grrr.
Ill definitely put the relay right above the fuel tank when I get this figured out. Im trying to find a good ECU to swap out. Seems like all the reasonable ones are 'no warranty no guarantees' so Id like to be sure before I spend that much on a stock part.
