today i pulled the N/S/R wheel off in the hope to find this knocking, thinking its a rear wheel bearing (still not ruled this out) i found the rear brake stuck on and on solid. strange as i had this apart two weeks ago to clean and regrease the pads and it didn't appear siezed then.
so i figured that with the brake stuck on it could be causing the knock especially with the groved disks. so being the chap i am i took this off and started to strip it down ready to clean the piston, cylinder and seal and dust cover.
what i found was a rusty mess that i had to clear and clean up.
the rust had grown onto the piston seal
so the cleanup process started and with an angled dentistry pick i got the rust out of the groove that houses the seal and then run a ball of wire wool on the end of a drill bit to clean the cylinder.
and then cleaned up the piston with 600 grit wet n dry paper and finished with wire wool
