Results 1 to 10 of 13
Thread: brake caliper overhaul
    cheshire, england
    today i pulled the N/S/R wheel off in the hope to find this knocking, thinking its a rear wheel bearing (still not ruled this out) i found the rear brake stuck on and on solid. strange as i had this apart two weeks ago to clean and regrease the pads and it didn't appear siezed then.
    so i figured that with the brake stuck on it could be causing the knock especially with the groved disks. so being the chap i am i took this off and started to strip it down ready to clean the piston, cylinder and seal and dust cover.
    what i found was a rusty mess that i had to clear and clean up.
    the rust had grown onto the piston seal
    so the cleanup process started and with an angled dentistry pick i got the rust out of the groove that houses the seal and then run a ball of wire wool on the end of a drill bit to clean the cylinder.
    and then cleaned up the piston with 600 grit wet n dry paper and finished with wire wool
    cheshire, england
    cleaned up the rubber by gently scraping the rust from the edge with a screw driver blade and washed off with brake cleaner
    cleaned the whole thing down with brake cleaner and blew it off with an air line, put some brake fluid around the seal and refitted that then a drop of fluid round the piston and slid that back home, cleaned and inserted the dust cover and now it should operate perfectly
    i have to wait for the wife so i can bleed it then i can try it, the noise was worse when it got warm so i am pretty sure this is the problem, there is no play in the rear wheel bearing so it really can't be anything else.
    i hope this helps those who wish to try refurb rather than buy new/ second hand or remanned calipers.
    tip...remove the caliper as you would when replacing the pads, put a tray beneath the caliper to catch fluid and pump the piston out with the brake, its far easier. dont forget to have a set of grips or pipe clamps ready so you dont loose all the fluid.
    Great little write up! That looks very easy to do indeed.
    Thanks Colt.
    Melbourne, Australia
    Good write up. It's very easy once you have done it. The hardest thing is getting the piston out when they are rusted like that. SOmetimes we have had to get one person using the piston removal tool and another with an air hose to try to push the piston out. Just keep in mind if the piston has any pits or grooves in it from rust then replace the piston. It will damage the seal and cause leakage.
    Waiting install
    Build Thread
    Feb 2011
    NE oHIo
    Some extra bits to think about if you do this job-
    Personally with that much rust I would have declared that caliper a goner. If there is too much clearance between the piston and the bore it will fail. If not now, eventually.
    Proper practice is to REPLACE the seal, but I will admit to using a CLEAN one over. When you are scraping rust deposits off, you will probably damage the seal.
    That caliper is a GREAT example of why you change brake fluid. Lack of proper maintenance caused the failure. If you cant see through your brake/clutch fluid, change it!
    -SP
    cheshire, england
    caliper and seal are fine indeed it is probably working as well as it did when new. i will only replace a seal if it really needs it i hate spending money on something if its simply ''to put a new one on'' especially if its no different than a new one.
    the piston was in great shape when i cleaned it up as was the cylinder and seal. no need to replace anything there, and with a constant hard servo assisted pressure there are no leaks and the piston returns as it should. i am a professional i have the ability to judge whats good or bad. and this was the sole cause of the knocking from the rear end. so i am happy
    also just completed an ABS delete after the ABS pump took a shit. the brakes are now quite a bit more responsive
    Charles Town, WV
    That's a whole lot of line left for no ABS. Pick up an STM ABS delete kit. All that mess on the fender can be gone.
    Great job with the caliper piston.
    1995 VR4 Coupe
    -Driftus Maximus- Not Verified Feedback Score 1 (100%)
    Corunna, IN
    Subscribed.
    ~2006
    Pittsburgh, PA/Wheeling, WV
    Nice thread! I did all mine and the worst part was putting the pistons back in and trying to get the dust boots to stay on the front calipers. Got "centrix" rebuild kits which seem to work ok and they were a lot cheaper than the dealership stuff.
    Feb 2011
    NE oHIo
    Quote Originally Posted by colt45 gto View Post
    Of course YOU are but look at the audience this thread can attract. They dont all have your skills and may do something that could be catastrophic. Thats why I added my advice to the thread. Think twice about brake parts since they may be the difference between having fun in your can and having a REALLY bad day!
    Work smart!!
    -SP
  • History
  • Information
  • Groups
  • Events
  • Resources
