Ninja Performance 75 amp Fuel Pump Power Supply Kit - $79 shipped
This is our first in house product. Do you have a power hungry fuel pump or multiple fuel pumps? Then you need this kit. Stop using china made relays with 14 gauge wire connector plugs. This is the highest amperage kit on the market. Made in house at Ninja Performance.
Finally, a fuel pump power kit capable of supplying your high current single or multiple fuel pump setup. No more over rated 10 gauge power cable that is actually 12 gauge in a thick outer cover. No more 14 gauge wire relay connectors that starve your fuel system of power. What good is 10 gauge wire if it connects to 14 gauge wire at the relay? All wire supplied in this kit is 100% OFC - oxygen free copper, and made in the USA. Relay is NOT made in china.
Specifications:
-Capable of supplying your single or multiple fuel pumps with up to 75amps @ 12V
-True 10 gauge oxygen free copper power cable Made in USA
-Ground and trigger wires oxygen free copper made in USA
-ALL ring terminals over sized for better power transfer - crimped AND soldered
Included in the kit:
-75amp @ 12V Bifurcated relay/ -40°F to +260°F / silver based contacts
-1' 10 gauge power cable from battery to fuse holder
-15' 10 gauge power cable from fuse holder to relay
-3' 10 gauge power cable from relay to fuel pump(s)
-Clear AGU fuse holder with 60 amp fuse
-3' 16 gauge ground and signal wire
-ALL ring terminals over sized for better power transfer - Crimped AND soldered
-1 crimp connector to connect 10 gauge power wire to fuel pump(s)
-Chris
