I just pulled off the ISC to see if there was anything I could repair. The stepper motor appears to extend and retract easily after playing around with it a little bit. I measured the resistance between the pins and they all read at 35 ohms, which is about 2 ohms higher than suggested (28-33 ohms is recommended) but I think 35 is an acceptable value. I'm going to throw it back in the car and see if it will work again, but I'm not holding my breath.
Also going to get started on testing out this paint...
