Page 30 of 58 FirstFirst ... 20282930313240 ... LastLast
Results 291 to 300 of 579
Thread: Project WDE Talon
  1. #291
    Looks like ALL of them took a shit, or he just forgot to put in ALL of the valve guides. I've never seen worn valve stem seals literally POUR oil out of the exhaust like that in a few minutes of idling.
  2. #292
    Apr 2011
    Mid-April 2011.
    Monroe WI
    I install my own stem seals. Shittt machine work ftl
  3. #293
    Well this was the previous owner so I wouldn't put it past him to do a bad job. Probably why he sold the car.
    So it looks like this fix won't be so easy, but it might actually cost me less from a monetary standpoint. Just gotta take off the timing belt and pull the head so I can get to work on those seals!
  4. #294
    Apr 2011
    Mid-April 2011.
    Monroe WI
    Keep every piece of each valve and spring assembly together, and seperate from the rest, and put it in a small bag or something and mark it accordingly to its matching port....some people dont do this then complain when a valves not seated properly or something.
  5. #295
    92vr4 verified
    Florida
    You don't have to take the head off. Take the cams out. Run compressed air in the cylinders to keep the valves closed. Get one of these or something similar.
    Overhead Valve Spring Compressor Stem Seal Removal Tool | eBay
    You may be able to barrow one from autozone etc.
    1993 RT/TT
    1992 GVR4 474/1000
    1998 Montero
  6. #296
    Quote Originally Posted by maTT View Post
    Yeah, I was looking at doing it with the head on last night. I was looking at a neat tool that seems to kick the crap out of these other cheap tools from what I've heard from other DSMers:
    Mitsubishi 4G63 Valve Spring Compressor
    Also found a decent price on some tools needed for the timing belt job:
    Jay Racing Timing Belt Tools Kit [TBTS] - $50.00 : Jay Racing
  7. #297
    Apr 2011
    Mid-April 2011.
    Monroe WI
    Just use a bench vice to compress the tensioner. But do it 1/2 turn then pause for a few seconds, and repeat. So u dont destroy it.
  8. #298
    Quote Originally Posted by Blackmount View Post
    I've heard of this method. I'll be thinking about this a lot today so I can make a thoughtful decision on my plan of action.
    I'm a little hesitant to buy a valve spring compressor that will only work on this head, especially at $70. There's one at Harbor Freight here with good reviews for only $15 and it will work on all heads and will work with the heads on the motor.
  9. #299
    iowa
    i made a compressor out of a 5/8 spark plug socket then cut a 1/3 of it away for a window to put the locks back, and use a c clamp to compress it down in and yes the vise method works well i have used it alot when doing timing belts
  10. #300
    Apr 2011
    Mid-April 2011.
    Monroe WI
    Oh and sometimes the tensioner needs some help expanding when u install it, so push on the tensioner pully to help the hydual tensioner expand. Also sometimes when u release the tensioner it will pull ut cam gears 1/2 a tooth and sometimes a full tooth. So compensate for that.
