Results 1 to 10 of 22
Thread: 19t Conversions!
    19t Conversions!
    Some of you may remember me from 3si. I used to do the 19t conversions on their. Long story short im doing here now.
    The price is $1775 with your cores. This price includes new compressor wheels, new turbines (HL) Clipping if wanted. And the upgraded thrust setup for handling higher boost pressures. I will also include any machining on the bearing housing or replacement if needed.
    The reason i only will do the upgrade with the HL turbines is because you need to match the flow of the compressor wheel with the turbine, if the air goes into the engine it also needs to come out of the engine, and the little L turbine is just not good enough.
    Comes with a 1yr warranty against any defects on my behalf.
    bumpppp
    Fowlerville, MI
    Can you use already converted 13T with WRX intake housings? Same price?
    yes i can use your housings.
    By any chance do you do any other conversions besides 19t?
    Wrench Monkey Not Verified
    Rochester, NY
    Nice, glad to see you back at it. Great price too. Paid 1700 for IPS 19Ts with the L wheel used last year.
    If I need a rebuild, could I look you up?
    what's the biggest you can do with 9b's? since the 13G's suddenly massively increased in price etc
    1996 GTO, Owner since 2003.
    19t with HL turbines is the biggest it goes from small to bigg, 9b,13g,15g,19t
    Ah crap, you weren’t doing this when I was looking. I think I even PMed you about it. Went with IPS, I got the HL wheel though.
    Pueblo, CO
    free bump for a great guy and product!
