Results 1 to 10 of 18
Thread: Help with 91 sl
    Apr 2011
    buffalo NY
    Help with 91 sl
    okay so i got this 1991 3000gt sl about a week ago not running... the motor in it has to be a fresh jasper re build it has never been fired he said he built it and never finished its out of a 94 the crank and cam sensors are the only two sensors not plugged in because i cannot find the plugs in the harness for them... did it switch between years did the 91's have a different set up for the sensors? please help
    Canaan NH
    Yes the 91 has a single cam/crank sensor combo up at the end of the rear intake cam. The 94 has them separate. You just need to rewire it for the seperate sensors, and if you dont want any latency issues you should replace the ECU with a 94 ECU. Not sure if its important on a NA though.
    94 3500gt vr2? verified
    NC
    that's because the 91 doesn't have the wiring for them
    but, u can just mount the cas sensor on the pass side of the rear head. the same way it mounts on a 91
    leave the cam/crank sensors unplugged. i've seen this done a few times.
    u can use a 93+ dohc on any year 3/s that's dohc
    Apr 2011
    buffalo NY
    cas? what is that? and your saying i can leave them un plugged and get a different sensor and plug it in somewhere else and it should start?
    Apr 2011
    buffalo NY
    never mind i looked it up will that work on my newer motor tho?
    NC
    yes, should work fine
    you don't need the 2 sensors on the drivers side (cam, crank)
    because you'll be using the single sensor on the pass side (cas) instead
    remove the cas from the rear head on the old engine, mount it on the new engine
    they do the same thing, but the cas is adjustable, so some people actually prefer that
    if you look at the 2 engines, side by side, it will make sense
    u should also check to see if both are fed spec or not
    this could cause some minor, but fixable issues
    count the # of vacuum lines on throttlebody of each engine, that's the easiest way
    if they both have 1 or both have 3, that will be one less thing to worry about
    also, in case you didn't know, our car's aren't "dsm's"
    most people don't
    Apr 2011
    buffalo NY
    they aren't dsm? and mine has one vac line on the tb but my other ? is the cas going to bolt right up to my motor they just leave a spot for it on the 93 up ones? or am i going to have to mod it?
    NC
    nope, not dsm's, not that there's really that much of a difference.
    1 vac line means most likely you have a fed spec engine and if your car is also fed spec, should make things easier
    so everything's installed and all together?
    don't still have the original engine?
    if you don't know what you're looking for, here is the cas
    Stealth 316 - CAS Replacement - DOHC 1991-1992
    what's the story here? what are you trying to do?
    is it finished? have you tried to start it already?
    Apr 2011
    buffalo NY
    this is the story with it... i got it and it didnt have driv shafts no fluids but oil no breaks and just a mess i got breaks got the clutch working (blead it) the guy i got it from said he had a motor built for it no the motor looks fresh and you can tell has never fired... the timing was off so i set it and put a starter in today turned it over since the timing and did a compression test and was not good cyl1 20lbs, 3 80lbs, 80lbs the rear bank 6 had 180lbs 4 had 180 and 2 had 120lbs so bent valves on the front? also there is a cas hooked up and still no spark. and no i do not have origonal engine and i want to drive it
    NC
    somethings not right...
    anything less than 100 per cylinder, i don't think it will start
    hope you didn't pay too much for this thing
    i'd have probably have someone look at it at this point
    if you're up for a long road trip, i have a running engine i'm selling for cheap
