The weirdest thing happened to my 3kt over the winter. When i put the car into reverse the reverse lights do not come on (which makes backing up at night time sooo much fun.) What weird is that sometimes when i pop it into neutral and then back into reverse they do come on, other times i can sit there for 10 minutes with no luck at all. Is there a sensor that turns on your reverse lights when you shift into reverse? (It is a stick shift.)
