So this weekend, I pulled my transmission to reseal it from a nasty leak and to also repaint it. Everything went fine and I am pretty sure that I put it back together correctly. But silly me, I didn't test the the gears before putting it back into the car and now it won't go into first, second or reverse. 3rd, 4th and 5th gear work without any problems. But 1st, 2nd and reverse are impossible to get into. I can drop the transmission fairly easily again, but I am wanting to know if there is something else I might be able to check before busting the case open again.
I know it's not a linkage issue as I can not shift it manually on the shifter shaft. So it looks like it's something internally. I am going to pull the shifter shaft to see if that bolt on the side came loose during installation. I would like to avoid take it out again, so any suggestions on what to check outside of the tranny that it could be would be helpful before I pull it again. Thanks,
Richie
I am getting a little too good at this.
