Page 2 of 8 FirstFirst 1234 ... LastLast
Results 11 to 20 of 80
Thread: So whats up??
    Runs on alcohol. The car does too. Not Verified
    San Francisco, CA
    It's all Justins fault.
    I know right?
    Quote Originally Posted by Granny View Post
    It's about time the TN sectiom come to life...carry on.
    BTW..I love u guys!
    Aww, we love you too.
    AEM s2 EMS | E316Gs | E85
    Quote Originally Posted by beepbeep View Post
    If this is true, why are you not coming to BRG????? And don't claim NG priority!!!!
    Quote Originally Posted by Intropy View Post
    At idle its fine. It'll be running at 13-14 while cruising and i'll look at it again (every few mins now) and then it'll be pegged off the gauge rich---. So i'll let off throttle re-apply and it goes back to normal for a few then the same thing over and over. I dont believe that I have changed the vacuum lines either, i'll double check that.
    Vacumm lines are hooked up correctly. I did find that my cas bolt had vibrated loose so I need to set the timing. Could that be causing the car to run rich?
    I mean if its out of time I should see some knock or something right?
    GREASE BUNNY
    VA
    It's not NG priority because finances are probably not going to allow NG........again.
    I want the car back together and both is not possible.
    BRG may be an option.
    I'll check into it.
    Quote Originally Posted by ZERO View Post
    Yeah I'd say that could cause the problem. IDT It would knock if the timing retarded.
    Driving Chris back.
    I'll check into it.
    Yea, we really wanted to go to NG as well, but with the move, starting up and now building the new shop, we have to accept the fact that we will be pretty busy at that time and just won't be able to go.
    BRG we are still trying to work out. Finding a new dog sitter is tougher than I thought. I can guarantee that you will have an absolute BLAST at BRG, though. You should REALLY look into it.
  8. #18
    Well I got the VSS replaced, changed the o2 sensors. I need to install Wayne’s crash bar, finish up the boost controller scanmaster thing and put stuff back together. I think that’s all.
  9. #19
    San Francisco, CA
    Cool, do you know if that fixed it yet?
  10. #20
    I know that was the problem but I haven't ran it yet. A lot of the seals were way up off the guide.
    BTW thanks for the help sell me bad heads and don't even help me fix them
