Results 1 to 3 of 3
Thread: No Spark, ....
    Pueblo, CO
    No Spark, ....
    ok, figured id start a new side of the trouble shooting.
    ok...i know i am getting fuel, changed out my plugs incase i fouled the original plugs.
    wired in the new PTU connector adn (easy, color matched) now a new issue...
    NO SPARK!!
    anyone know what my specs should be for these to test adn how exactly do i test them adn can anyone who has done this before help! lol Im just not electrically inept to do this for some reason. not sure if my multimeter is shitting out on me, but seems all my readings are off. I have them set to 20k ohms.
    I was originally getting spark, when i swapped ptu connectors, it was doing the same start, then immediatley die, then it idled for about 1 adn 1/2 sec adn then died then now I get no spark at all.
    AEM PRO showed start syn ON when i was cranking, so i sees the cas, but not sure what else to test, or check or well, not sure on anyhting else at all...some advanced help would be greatly appreciated
    oh i bought a new battery too btw since the old one was deader than a doorstop
    Ft. Lauderdale, FL
    Sounds like it could be the cas. If you can, with the key on, put a multimeter on the ground and signal wires (I think blue and black, pins 1,2 signal, 4 is ground) and turn the crank by hand. See if the voltage is changing like it should. You can also crank the engine, but you may need an analog meter for that.
    Pueblo, CO
    i have both now to try
