Well kinda. It needs work before she is a driver again. But the project has begun. I just picked up a 1996 3000GT VR4 in dark green metallic w/ two tone black / tan interior. Clean title. 96,xxx miles. Sunroof. New tires, new clutch, new timing belt, new tie rod. Only after market parts I see are a Samco BOV and a K&N air filter.
Car was not running when I bought it. Motor spins free, can hear compression. Previous owner said a timing belt was done and couldn't get it to run right after that. Said he drove it around the block once, then couldnt get it started again, it would turn but not fire. The timing belt covers were off and the valve cover pulled on the front, he was trying to see if any valves were bent.
Now I can see right from the get go it needs:
A windshield, a boot on the steering arm, driver seat upholstery, new motor mounts, passenger side headlight, needs floor mats, looks like the transmission leaks a little. And of course getting the engine running.
Curious to see what you guys think the car is worth ? I think I got it for a good price and have wanted to build one of these for awhile as this is my 4th one.
Now these are some thoughts I have for the build
Pull the motor, Have the heads ported and polished / gone thorugh, check the bottom end while its apart, most likely do rings and bearings while its out, all new gaskets. Rebuild the tranny since all my other ones were a bit notchy with a little over 100k on them. Bigger turbos ( open to suggestions ) down pipe. Front mount with hard pipe kit. Upgrade fuel pump. Boost controller. Injectors ( open to suggestions ).
Already have: Borla exhaust, Apexi NEO air fuel controller, auto meter gauges.
So lets hear some opinions !
