Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 51
Thread: Car Related Tips Thread
    CT
    Dont rush dont rush dont rush.
    I forgot to put my oil cap back on then drove 50 miles. In the same week I forgot to re-bolt my front brake hose bracket to the strut, it fell into the axle and severed the line in half while I was on the highway.
    My engines life and then my life were risked because of ONE STUPID THING because I was rushing.
    Forum User supporter
    When ever possible use the right tool for the right job. Short cutting will lead to problems, breakage, anger management issues later. If you don't have the right tool, beg, borrow, or buy it It makes life sooo much better.
  3. The Following User Says Thank You to Rocket For This Useful Post:
  4. #13
    Don't listen to steve68, your ringlands are not broke!
    Go OEM on your oil and water pump, tension pulley, and idler pulley.
    Get a service manual and read it!
  5. #14
    Not A DSM verified
    June 2006
    Utah
    Why? Was it there on the factory gasket? Did it leak before? I stand by my advice but feel free to ignore it. Anyways....
    Yes, there was. I don't know why everyone seems to think that you're not supposed to use RTV on the valve cover gasket? You're supposed to use a small dab at each corner of the cam humps. It's right in the service manual and it's there with the factory gasket.
  6. #15
    Canaan NH
    Exactly correct. As I stated dont use it were you dont need to. I always use it in the corners of the VC gasket as called for, but would you use it were its not needed? Some think they need I it when they dont, I have seen people use it on head gaskets even.
  7. #16
    Not A DSM verified
    June 2006
    Utah
    Oh, it seemed like you were saying to not use RTV, PERIOD, when changing the valve cover gasket.
  8. #17
    Soak bolts with PB Blaster to loosen them up AND WAIT at least a day if possible before loosening them up. Makes life so much easier.
    Use Neversieze on all turbo/exhaust bolts when reinstalling.
    Never Ever over tighten bolts.
    Try and only do one mod at a time to lessen the chance of trouble-shooting when something goes wrong.
    "Life should NOT be a journey to the grave with the intention of arriving in an attractive and well preserved body, but rather to skid in sideways, chocolate in one hand, martini in the other, body thoroughly used up, totally worn out and screaming "WOO HOO what a ride!"
    ----------------[2007 Ride of the Year.................................. 3.5 Stroker I did. w/DBB DR1000's
  9. #18
    Quote Originally Posted by oohnoo View Post
    This^. This^. This^.
  10. #19
    Canaan NH
    Never mod and engine untill you are certain its healthy.
    Well thought out mods > Most expensive mods.
  11. #20
    Newark, DE
    3SX Performance - Service Manuals Backups 3000GT / Stealth*-*Mitsubishi 3000GT*/*Dodge Stealth Parts
    All great tips in here. I will add, patience and fortitude. If you find yourself needing to "go gorilla," you need to step back, and reread this thread =)
