Results 1 to 3 of 3
Thread: Timing question 91 ES
    Dec 2010
    I have just been and checked the engine timing with my timing light and the timing was set to about 25 degrees. I tried to reset it to about 7 degrees but the timing mark on the belt jumps backwards and forwards rapidly about 4 degrees. Any ideas?
    Also when I try to accelerate the car chokes up and I have to floor it to get it to clear.
    Stealth owner since '91
    Sthrn NH/Eastern Ma
    Did you ground the set terminal over by the battery?
    It's the tan one bundled up with a black one and a blue one tucked in under the wiper motor. Remove the cover on the terminal and use a jumper wire to connect it to ground
    (the black connector is fr testing the fuel pump, the blue is the tach signal for a hand held tune-up tach)
    Dec 2010
    no i didn't, i will do that thanks.
