Voltage on both wires means that the wiring appears to be fine. It would indicate a bad dimmer/rheostat though which is a pain.
knob was turned up all the way.
readings are:
black/yellow = 11.94 (went to 11.90 as i turned the knob off)
green/white = 11.14
car won't start due to no gas lol.. i can't charge my battery at home, so you'll see the readings slowly go down.
Unless the black wire burnt up along with the dimmer. I wanted to make sure we still had a ground connection there.the black wire is a ground wire, so measuring voltage to it and measuring voltage to ground is basically the same thing.
Unless those two wires are still shorted together somehow. Hard to say without putting a load on it which is why I wanted to put the dimmer back in. (under load the black/yellow should read less than the green/white)Voltage on both wires means that the wiring appears to be fine.
That's not good. Either the dimmer is toast or the wires are still shorted.black/yellow = 11.94 (went to 11.90 as i turned the knob off)
Try testing the dimmer.
Unplug the dimmer
Put the meter on 2k
on the dimmer measure between pin 3 (were the black/yellow wire goes) to pin 2 (were the black wire goes) while turning the knob up and down.
sorry, i misread the volt meter... plus i have a bad memory. I went and retested and heres my OFFICIAL results lol.
black/yellow = 10.90 (10.95 with the knob on)
green/white = 11.16
That's better, but I'd still like to see it change more.
Go ahead and try that test on the dimmer switch.
just the dimmer itself? with no plug in it?
Yup,
Unplug the dimmer
Put the meter on 2k
I get a reading of 046 and 047 when moving the knob up and down.
Just checking, are you on the ohms setting (2k) or are you still on DCV?
