Or rather, I can't get it to stay.
Once out of maybe 25 or more times, reverse would pop out of gear when I would lift the clutch. I'd clutch in, neutral, 1st gear, reverse, and it'd be fine. However, this time it's been 2 days and reverse has not worked at all - I've had to push the car.
All other gears, 1-6, work fine and no grinding. I can't tell if the 6spds have a reverse synchro or not, though I've seen info on the 5spd on Stealth316.
I checked the usuals - it's 100% stock so I don't think anything is hitting the arms, and I don't visibly see anything that would. I tried adjusting the linkage under the shift boot without any luck.
I can get into reverse fine. It just grinds slightly then pops out. It isn't that I'm not in reverse, since my other 6spd works fine, so I know I am not derping.
I may try putting it in reverse and then popping the cables off, and I also saw a TSB for one part on the top of the trans, so I may try that if popping the cables still makes it pop out of reverse. I wanted to post here for any updated thoughts or suggestions - almost all the info I found was 06 and prior.
it's in a box in my garage! some JDM Chappy smoothed the syncro's engagement gears doing 180 degree turns!
