Results 1 to 10 of 16
Thread: wont start this morning?
    Pueblo, CO
    OK, well I leave for Vegas tomm and decided to drive her before I leave...Started it up and it would start idle for a half a sec then kill out. did it like 5 times and would idle for half a sec then immediatly kill itself. Not sure y? Last time I drove it(2 nights ago) was fine and only had it parked. ? Kinda wierd. battery died, so it was on the charger after first few attempts and still nothing. (btw i know i need a new battery, but after it starts she is usually good for the day)
    Why would it try to idle then kill itself? I didnt touch the egine bay or anything at all??
    Canaan NH
    Everything I can think of you have already gone aftermarket on.
    Pueblo, CO
    i know right?
    Canaan NH
    Are you still using the MFI relay? That could cause it if its bad.
    Pueblo, CO
    for my click click start?
    Canaan NH
    No. This relay supplies power to the ECU and the fuel pump. Not sure if it gets eliminated with AEM and hot wire kit.
    Pueblo, CO
    well, when i turn the key to on, i hear the walbro whining. once it stops i start the car. i know its got power and all. checked the eci fuse, and its all good. maybe, I'll uplug the neg cable, wait till tonight and then retry....
    your not e85 are you?
    Pueblo, CO
    ya. y?
    Colder day? a friend had that issue and had to make a adjustment on the AEM. I can't remember if he leaned it out a bit or richened it up. It was just an issue with the mixture when the engine was cold.
