Results 1 to 10 of 10
Thread: how to leak test blow thru setup
    Midland,MI
    How would I go about leak testing on my blow thru setup
    Pueblo, CO
    i would like to know this also
    Midland,MI
    I guess we could always put the stock bubble and pipes on and do that but what a PITA
    Pueblo, CO
    i dont have my bubble anymore, but sure I could get one. I think im gonna fabricate a pressure tester for blow thru set ups.
    block off one turbo with a rubber pipe cap. Then build a circular pressure tester for the other side like this:
    Intake Leak Pressure Tester
    Tried to find it on this site, but only found it on the other site.
    3000GT/Stealth International Message Center
    92 Red VR4 - BPU: Sold
    93 SS VR4 - BPU: Sold
    94 VR$ - Not Stock
    Light travels faster then sound. This is why some people appear bright until you hear them speak.
    "Transire suum pectus mundoque potiri"
    (Rise above oneself and grasp the world).
    "Give me a fixed point, and I will move the Earth."
    (Archimedes)
    I have come here to chew bubblegum and kick ass... and I'm all out of bubblegum.
    (Roddy Piper)
    go to the hardware store and buy a valve stem and a pvc cap
    drill a hole in the cap and push the valve stem through it. then just remove the ic pipe going to the maf and put in the pvc cap. pressurize and bam your done.
    the basic go fast bits...
    Tuned by Ray Pampena
    Just a fun Daily Driver.
    SKADOOSH!!! verified
    Prince George
    Block off the least accessible turbo, then fit a cap with a valve stem onto the other.
    Photobucket
    Charles Town, WV
    Be VERY careful that those caps don't blow off the turbo and fly around - I did a similar tester for my evo and somewhere around 25psi the cap popped off. Scared the peanuts out of me. The black couplers should be right near the PVC caps.
    1995 VR4 Coupe
    One fix at a time verified
    Kansas
    I have a Rob Beck pressure tester that fits in the stock air bubble. I ended up getting a 3.5" to 3" reducer and a 3" cap so I can pressure test my blow-through setup. I couldn't even build any pressure because it was leaking out my MAF sensor so I'm going to see how well I can get it to seal up. You can build a pressure tester pretty easily just block one of the turbos off.
