Page 4 of 22 FirstFirst ... 2345614 ... LastLast
Results 31 to 40 of 214
Thread: 6g74 / built atx
  1. #31
    TT ATX Owner verified
    Shallotte, N.C.
    Loving it down here 8) Closer to the ATL and the Family in Jax Fl. Right now Im just missing my car. Should be out of the body shop in another week or two. Im really wanting to have it mostly done "mechanical" by BRG. You making it to BRG?
    1993 TT ATX "Boostin the 10:1 since 2005"
    TT ECU, DR650s, Port matched manifolds, 550inj, Walbro 255, Apexi SAFC2, Scanmaster 3, 3SX Downpipe, Full 3" Exhaust, 22" Chamber Tube, Magnaflow Muffler, Urethane Motor Mounts, Intrax Sport Springs, Kazera KZA 18x9 rims, ALpine SPS speakers, Infinity Bass Link, Polished intake manifold, Valve cover, Spark plug cover, and various blingy bits, 99 Side Panels, 99 rear center garnish.
  2. #32
    94 3500gt vr2? verified
    NC
    will try to make it if the car is all done and i have any $ left, lol
    will be at ng no matter what
  3. #33
    Ft. Lauderdale, FL
    Supposedly you can damage the torque converter or the atx shaft by running the atx like that, but you didn't drive around or anything so you should be ok. I think I had my torque converter installed wrong (not completely in) for a little bit and I did drive (a very little bit) on it. I did re-install it correctly and I haven't noticed any signs of damage. It is possible the squealing noises you heard could have been some damage happening though. Was there any fluid in the torque converter? Due to the way it works, it doesn't seem likely that the torque converter could prime itself.
  4. #34
    NC
    i couldnt drive if i wanted to, lol. it didnt budge in any gear
    in all gears except neutral and reverse its making this faint buzzing sound (sounds electrical)
    i intentionally left fluid in the tq converter, i didnt know if it could prime itself, so thought that was safer
    i shouldve dumped it and poured new fluid in it
    squealing noise was the plenum. i could tell it was definitely from the plenum or rear valve cover.
    tightened the plenum bolts while it was running so that was definitely what fixed it
  5. #35
    That downpipe flow is definitely backwards! I would be getting in contact with the ebay seller right away....thats a worse design then factory!
  6. #36
    NC
    i had an idea what might be wrong
    thought maybe the ground wasn't good enough
    so i attached a nice thick ground wire from the trans directly to the battery
    still no good
    that wouldve been too easy, lol
    weather isn't cooperating, so it looks like it will be another week before i get any more work done
    this buzzing sound is really puzzling me
    sounds like when youre trying to start a car with a dead battery
    that real fast clicking sound, but much quieter
  7. #37
    STL3S Not Verified
    Oct 2005
    You will wish you stuck with your original plan and gone for the MTX.
  8. The Following 2 Users Say Thank You to whitedragon For This Useful Post:
  9. #38
    I AM IMPORT POWER
    Driving Vicki Crazy
    Quote Originally Posted by whitedragon View Post
    This
    -Chris
  10. #39
    NC
    i may still go that route
    i want to give the atx a 2nd shot at least
    i dont like not knowing why something isnt working
  11. #40
    STL3S Not Verified
    Oct 2005
    It doesn't matter if it's working or not. You will be annoyed at how "slow" it is with the ATX, how it doesn't shift when you want it to, and how it runs out of gearing so quick, and it never seems to be in the powerband.
    My 3.5 with IPT's built ATX was still slow, the torque converter they gave me never seemed to work right, and it seemed to never shift at the right spot ever.
    Creative had a 3.5 MTX and would regularly spank me, and that's even with my extensive exhaust mods and his stock downpipe and catback. Unless you are planning on having a wife or gf drive the car that can't drive a stick, ditch the ATX.
