Page 18 of 22 FirstFirst ... 81617181920 ... LastLast
Results 171 to 180 of 214
Thread: 6g74 / built atx
  1. #171
    Ann Arbor, MI
    thanks for the info i'll look into it. it's about a 9 inch tear and that whole area under the tear has some pretty good wrinkles.
    got the 170* thermostat in
    took it for a drive, still seems way too hot under the hood to me, although my guage doesn't ever touch halfway
    going out of town for a few days, so that means i have to somehow find time to finish all that other stuff next week
    and try to make arrangements for someone to room with and someone to follow up
    someone's gotta be passing through nc... no replies in my post for it though
    What about the 3SX crew?
  2. #172
    94 3500gt vr2? verified
    NC
    dunno if they're all going or not, i'll check
    me and suthnr are only names on registration list from nc
    not a whole lot done today
    finished up complete ac system flush today, all new orings also. will charge it up tomorrow and see how it holds
    anyone know if we have are supposed to have an orifice tube or some kind of filter somewhere? i didn't run across anything
    drained and capped off heater core. it's being bypassed for now
    installed new slave cylinder and bled lines. feels a little stiffer now
    think i need to adjust the pedal again tho
  3. #173
    NC
    well, put 24oz in and compressor won't kick on
    found a blown 20amp fuse, but that was for the condensor fan i think
    replacing that didn't help
    quite a few things to test now
    no ac will suck
    good news, the o2 bung is only going to cost about $30 installed
    hopefully get that done today or tomorrow
  4. #174
    Mad JDM Tite
    STL
    no ac will suck
    Is the ac controller under the glove box plugged in? If not your compressor will never engage. It's the little black box attached with the lower dash plastic under the glove box that also has some venting molded into it.
  5. #175
    NC
    didn't think that's what it did exactly
    it is plugged in tho
    some of my parts got mixed up, but is the same part# as the other ones i have
    i could try another in case somehow this one is randomly bad
    i'm leaning towards bad connection on the clutch wire tho
  6. #176
    Ann Arbor, MI
    Email or PM Suthnr, otherwise it is going to be a lonely trip!
  7. #177
    NC
    got the o2 bung and sensor in. now just have to put the downpipe back on and fish the wire through the floor.
    while waiting on the downpipe to get done i went ahead and drained the gear oil and pulled the old axle apart.
    inner axle wasn't too bad to get off and it slid on to the new axle fairly easy
    before i put it back in i'm going to replace the axle seal. hopefully i have the right one
    also need to install the oil pressure sender
  8. #178
    NC
    well, not much progress today
    got the axle seal in at least
    old one came out fairly easy with a plastic prybar
    put some oil on the new one and it wasn't too bad to get in
    almost forgot about the broken lug nut stud
    they're usually fairly easy to replace
    not this time, thanks to this abs ring
    broken lug stud
    back of knuckle
    abs ring is all kinds of iin the way
    and i'm having a hard time getting the bearing out
    any help with this would be appreciated
    i'm trying to just get a whole knuckle and control arm from a local guy
    seems like the easiest option for now
    if u look closely, you can see my ball joint is also shot
  9. #179
    Ring around tyre joints and or local mechanics and see what the going rate is (if anyone knows how to get it out)
    But hey, good excuse for new lower control arms!
  10. #180
    NC
    waiting to see when i can get the control arm/knuckle/hub from this guy
    i'm cutting time so close, it's not even funny
    guess as soon as i can get some free time, while i'm waiting, i should work on this
    having a hard time getting that plug out so i can get the oil pressure sender installed
    is it just me, or is the oil pressure switch in the wrong hole?
    or does it not matter which goes where?
    and if so, and i can't get this plug out, which of the 2 would you prefer? i'm thinking the guage
    then i still need to put the axle in, it's ready and should be fairly easy, new axle seal is already in
    fill up trans with synchromesh
    downpipe on and route o2 through floor, still have to find the right hole, think it's behind the heatshield
    figure out why my ac compressor clutch isn't engaging
    test out the radiator fan
    secure the battery
    find a helmet
    probably going to need an alignment
    registration/taxes/inspection
    hopefully squeeze in a good 2 hour test drive somewhere
    and also if i don't get my stereo in, i'm gonna be bored out of my mind on the road lol
    last minute oil change, coolant flush, gas up and go
    i really hope that's it, because i don't know if i can handle anything else
