finally my car starts with the key! no more push starts
i went back to the autostore, this time persistent that they pull every starter they had in stock for comparison
i was thinking something was up because the new one i got looked just like the 2 atx starters i have
somehow the one i bought ended up getting stamped and boxed up on the assembly line as an mtx starter, but it was actually an atx starter
anyway, they gladly exchanged it after seeing the difference
i can't believe the last guy had the nerve to say, "u sure u don't have your flywheel on backwards"
don't think that's even possible, lol
after getting the new one, i took some measurements
the mtx starter is about 8mm longer, which is almost how thick the flywheel teeth are (10mm i think)
comparison of mtx/atx starters
got new bolts too, the old ones i had were getting stripped out
found some m10 - 1.25 x 50mm on the shelf and were only like $2 for the set
these worked pretty good, but i wouldn't go any shorter than 50mm, oem length is 60mm i think
