Page 14 of 22 FirstFirst ... 41213141516 ... LastLast
Results 131 to 140 of 214
Thread: 6g74 / built atx
  1. #131
    Ann Arbor, MI
    Where did the flywheel come from? JDM NA flywheels are 1cm smaller in diameter than the USDM flywheels. I found this out the hard way when I installed a JDM engine in my fiancee's car. Had to drop the trans, again, and put a USDM flywheel on.
    Told you to inspect the starter wiring harness! Glad you solved that issue.
  2. #132
    94 3500gt vr2? verified
    NC
    yeah, thanks man, you were right first, everything looked good to me at the time tho
    then chris told me to look for that specific connector. guess i messed up with all that tugging on everything
    i'd prefer not touch any wires again anytime soon, lol
    flywheel is from advance auto and for a 3000, so i'd assume it's right
    actually, got both the starter and flywheel new from them, so if one or both are bad or damaged, i should be covered
    i'll get starter tested tomorrow hopefully
    now, to figure out this o2 sensor wiring
    having trouble locating the connector that would normally go near the shifter through the floor to the downpipe
    only one i see so far is the one on the alternator harness, but don't think i can use that
    i'll hopefully figure it out while doing the interior swap
    while i'm at it, anyone have advice on a wideband o2?
    also, for different placement? not a single hole anywhere on my current exhaust, so i can put it anywhere i want
    also, would mil eliminators be an option worth considering?
  3. #133
    NC
    starter tested out good. now what?
    tried click click start, although i don't think that even applies to my case
    starter spins fine and without hesitation, just doesn't throw out far enough to turn the flywheel. looking at the teeth of the starter, it looks like it's barely touching the flywheel at all, which would leave me to believe it's the wrong specs or defective. wish i had a known good 5spd starter to test on it. it could even be that my flywheel is not right specs, which would be much more of a pita. would like to figure it out soon before my new axles come in. any help would be appreciated
  4. #134
    Ann Arbor, MI
    Sounds like the flywheel is too small. I had this same issue.
    Just to verify, try another 5speed starter.
    You aren't installing it upside down are you?
  5. #135
    NC
    upside down
  6. #136
    Ann Arbor, MI
    Are the teeth on the starter facing the teeth on the flywheel?
    Please verify that you have a MTX starter and not an ATX starter. Please verify you have an NA flywheel and not a TT flywheel.
    If the starter is not engaging but checked out good then there is a mismatch here.
    The FWD flywheel is LARGER than the AWD flywheel.
  7. #137
    NC
    i'm sure the starter is in right. it would fit backwards with teeth facing away from flywheel?
    also, ran 8 guage wire straight to the solenoid, still same results
    tried a whole seperate battery on the starter, connected with jumper cables, still no change
    i think best option is to find a known working starter to test
    i set the new flywheel on top of the old one. they looked the same to me
    didn't measure them with a micrometer or anything tho
    on a side note, i found the o2 wires, tucked under the carpet and further from the shifter than i expected. also, not the connector i was expecting
    debating getting a new one, but don't think i need to
  8. #138
    Ann Arbor, MI
    If the flywheels are truly identical, then sounds like you have an automatic starter. The manual trans starters have a longer nose.
  9. #139
    NC
    i have a couple of extra atx starters, that's all i had to compare it to
    they looked identical to me as far as overall shape and size and length of nose
    checked the throwout and that looked the same too
    the teeth looked like they might be slightly different, but hard to tell
    also, on the new starter you can see where the very edge of the starter teeth where it was rubbing a little
    so i'm pretty sure something's not right with the starter and it's not something i did wrong
    trying to borrow one from someone local to test and be sure
    i'm quickly running out of time
  10. #140
    Ann Arbor, MI
    Then you have an ATX starter.
    You require a MTX starter. March down to your local auto parts store and buy a MTX starter.
