Page 13 of 22 FirstFirst ... 31112131415 ... LastLast
Results 121 to 130 of 214
Thread: 6g74 / built atx
  1. #121
    Quote Originally Posted by Alex3000gt View Post
    As I recall didn't you saw through a harness a while back?
    Nope, I bought a harness adapter and hacked into it.
  2. #122
    94 3500gt vr2? verified
    NC
    i found the missing connector on the passenger side under the dash, so that's connected now
    i believe everything is hooked up correctly
    everything i thought to be a major concern has been resolved
    now when i turn the key to start, i hear the fuelpump making all kinds of noise, but nothing from the starter
    changed out the starter relay, no change
    grounded the etacs, no change
    i'm going to try to hotwire the starter or push start it tomorrow
    if i push start going really slow, i don't think it will do much harm
    that's the only thing i can think of to help figure out what the problem is and see if everything else is working properly
    any advice/tips would be greatly appreciated
    aside from working on the no start issues, i flushed the ac lines
    everything's hooked up and with a new compressor, new drier and all new orings
    radiator and condensor back in, although i think i need to swap fans
    apparently i put my old 92 radiator in, but one of the connectors for the fans are different, 6 pins instead of 4 pins
    no big, deal, i can just switch that one fan out
  3. #123
    Ann Arbor, MI
    Is all wiring going to the starter hooked up? Verify and then trace the harness back and double check.
  4. #124
    NC
    it's hooked up correctly, that's probably the easiest thing i've done yet
  5. #125
    NC
    It's ALIVE!!
    Roll started it down the driveway
    As long as I park on a hill with nothing in the way, should be set, lol
    Took it for a drive around the neighborhood, everything felt and sounded pretty solid, but i think it is running a little lean (no o2 sensor at the moment)
    Now that I know everything works for the most part, I can start wrapping everything up and get this thing back together.
    Left to do:
    - Either figure out the no start problem, or maybe install a push button start
    YouTube - ‪shooter83's Channel‬‏
    - o2 bung in the new downpipe and wire in the sensor
    - Finish up the battery relocation, brackets for the battery and install the new power and ground distribution blocks
    - If time and $ allows, replace both axles
    - Get dash back together
    - Finish Interior swap
    - Then a bunch of cosmetic and sound work, and should be all set
  6. #126
    fantastic!
    just keep an eye on fluid levels and you'll be sweet! Put about 15K on my 3.5L so far and loved every minute of it! the beauty of an N/A engine.
    Many congratulations, have the little loose ends tied up and start enjoying her!
  7. #127
    NC
    chris from ninjaperformance is the man!
    thank you, i found my last wire, that's a tiny little fucker too to be causing so much trouble
    car starts now, but the starter is actually bad, even though its brand new
    which i was already assuming because it wouldn't engage when hot wiring it either
    at least now the key makes it spin and do nothing instead of just doing nothing at all, lol
    i think they gave me an auto starter and it's spinning, but not fully reaching the teeth
    i'll be extremely pissed if it damaged my brand new flywheel
    anyway this wire wasn't seated properly, and i was thinking it was just a ground lol
    this is all that was preventing the starter from spinning, although my new starter is either bad or they gave me an atx starter which engages a little bit shorter
    So i guess next on my list is to replace the starter
    Then find a place to mount my new coolant overflow tank and hope it works proplery
    ignore my temporary ground lol, it's just temporary and i'm still working on a custom ground wire kit
    and even more so, disregard the balled up shirt, it's insulating my temporary power distribution block, which is actually a battery terminal, lol
    i have a new one, but haven't installed it yet. these other issues been keeping me busy
    Then i need to fix my power windows, they randomly stopped working yesterday
    I should also test my speedo, rpm and fuel guage while i'm thinking of it
  8. #128
    NC
    aghh, speedo fuel and everything else not working
    only thing on the speedo working is the flashing ecs sport light
    now also my temp and battery guage not working
    wtf, for everything i fix, at least 1 other thing breaks
  9. #129
    mate I say this now, Do not crank the car with the auto starter in there. My car started maybe 20 times before it chewed up the end of the ring gear. It catches the flywheel by about 1mm...that's all
    So do yourself a favor, dont crank it anymore until you get that MTX starter! the throw out is ALOT more.
  10. #130
    NC
    not sure if it's an atx starter or not, but it's definitely not catching enough to turn anything at all
    think i've only tried it 2 times, once jumping the solenoid and once with the key
    so if there is any damage, hopefully it's minimal
    when i have time later i'll spin it over slowly by hand and inspect the teeth through the starter hole
