Results 1 to 8 of 8
Thread: 413.5 bhp at the flywheel from standard injectors
    scotland .uk
    well i was up today at hypertech getting the car fueling sorted. duncan couldnt get the right pintil caps for the 450's in time so we set the car up on the standard injectors with the s-afc with some good results.
    chart shows the last time i was there compared to today.running 1 bar boost ,45psi fuel pressure, no knock through out the range.413bhp
    we did hit 416 but as standards are only good for 417 left it a bit lower.next time we'll get the 450s' in and hopefully get 430+
    first chart shows last time and todays.
    and one for the tech heads,duncan said this would confuse a few folk,im lost even with the basics
    So this is just the engine on a dyno? Seems like good results on stock injectors.
    Pueblo, CO
    Hmm, 413 on stock injectors and safc? doesnt seem realistic. How can you get that power out of 360's? doesnt add up. What kind of turbos? what kind of dyno?
    scotland .uk
    its running 13ts' and uprated fuelling,set the fuel at 45psi which isnt alot. it was on a dyno dynamics dyno one of the more accurate ones in the uk ill be fitting 450 inj next just waiting on them being serviced. 360 inj. top out at 417bhp
    Is this an engine dyno or chassis dyno?
    DG
    Driving Vicki Crazy
    It's chassis, then it guestimates at the flywheel HP.
    -Chris
    scotland .uk
    not into all this tec stuff like you guys but the car sure feels alot better now .its only figures at the end of the day,just as long as i can keep with an m3 im happy and my car runs
    Odd.
    Most chassis dynos are content to report delivered HP rather than introduce a bogus number based on a guess on drivetrain loss.
    Dynos are relative devices anyway. They are great for comparisons of the effects of changes as measured on the same dyno, but dyno-to-dyno there's a lot of variation. I don't put much stock in dyno numbers, even my own.
    DG
