Results 1 to 10 of 14
Thread: Can I drive w/o secondary 02s?
    Can you drive without the secondary 02 senors installed? I have a place to be in a couple of hours and both secondary sensors have not arrived yet. I know they are only there to check an see if the cats are working...
    Is it safe?
    Thanks, John
    Ft. Lauderdale, FL
    You can drive with no O2s. Check engine light may come on and car will run richer than normal. Perfectly safe though.
    Member Not Verified Feedback Score 4 (100%) dpartinvr4's Avatar
    wheatfield, IN
    it will sound weird with nothing plugging the holes.
    Taichung, Taiwan
    Lol, it will be loud but manageable.
    You could put a bolt in there if it's that big of a problem.
    Cazenovia, NY
    Quote Originally Posted by RL7 View Post
    Secondaries are for emissions purposes only. They have nothing to do with adjusting AFR's.
    Prince George
    Yep, you can even run on one primary. Just as long as both banks are feeding it.
    Photobucket
    94 3500gt vr2? verified Feedback Score 9 (100%) n2nsanity's Avatar
    NC
    Quote Originally Posted by J_Parker View Post
    can you elaborate on this? i actually have a problem with this
    my car is ca spec, but my engine isn't. it had an o2 sensor on the front manifold, but the ones i'm using now don't.
    what can i do about this?
    Cazenovia, NY
    The ECU might send the car into limp mode, although I'm not sure if our ECU's will do that. The one O2 would have to run in open loop if the O2 sensor is unplugged.
    You could either grab a fed spec ECU that uses the single O2 sensor or possibly splice the front O2 sensor into the rear O2 sensor, that way the ECU will at least get a signal from both sources.
    Prince George
    You'll have to splice them together, yes. If you can find yourself a bung and relocate it to about 8 or more inches from where the rear bank plumbs in.
