Results 1 to 10 of 10
Thread: Air/Fuel Controller...Help me choose
    Forum User Feedback Score 0 hitman17's Avatar
    Lancaster/Reading PA
    Lightbulb Air/Fuel Controller...Help me choose
    Ok so I'd like to get around 400 awhp with my set up. I have 13g turbos, supra fuel pump, FMIC, GM 3.0 MAF and 450cc injectors. I know I may be a little small on the turbos, but it is what it is. This will be a blow-thru setup. So, what controller would be best for my setup?
    I was thinking about the MAF GEN II, or the AFC NEO. Opinions??
    Stuper Moderator Feedback Score 0 HilbillyHomeboy's Avatar
    January 2003
    Either one will fit the bill. Just make sure if you buy a used NEO, it's not one that hasn't been reflashed as the early ones do not work properly unless they've been sent back to Apexi for updating.
    Douches
    im really confused. it sounds like you already have a 3" GM MAF, if so than im pretty sure you need the MAFT to translate the GM signal to the Karman signal. right? so i would just go with the MAFT and see what the car can lay down. if you come up a few hp short you could then try to add something small like jackhammer cam gears, an apexi neo (to use WITH the maft), or maybe some water meth injection.
    on a side note does anyone know what version of the Neo is the one that was corrected from the factory? i got a V1.200 that the shop i bought it from claims is all set for a 3000GT/Stealth... but this is the same shop that claims to be able to make 400awhp on 9b's. i just dont want to go for tuning then find out i wasted my time, ray's time, and a ton of money.
    the basic go fast bits...
    Tuned by Ray Pampena
    Just a fun Daily Driver.
    I believe I would need the MAFT if I went with the AFC NEO, but if I go with the MAF GEN II, I don't need the MAFT. Can someone confirm this??
    Quote Originally Posted by hitman17 View Post
    Im assuming this is what you mean by "MAF GEN II"
    MAF Translator.
    if so the "MAF GEN II" is still just a MAFT, just the newer version. its even called a MAF Translator Gen II on that site. so no matter what you will need some sort of translator (either the MAF Translator Gen II or the original MAFT). both will work, but i think since your pushing the 13G's kinda hard the MAF Translator Gen II might be a better choice of the two because it allows for 'finer' tuning than the original.
    that being said i think your three options are
    1) MAF Translator Gen 2
    2) MAFT (original)
    3) MAFT (original) + Neo
    no matter what you cant use just the Neo, every option requires some sort of translator.
    When I read your original question I was confused because it sounded like you were going to run either the MAF Translator Gen II OR just the Neo without any sort of translator. This confused me because as far as I know you NEED a translator (Gen 1 or 2) if you run a Neo with the GM MAF.
    that’s why I said, “just go with the MAFT and see what the car can lay down.”.
    I probably should have said ‘just go with the MAF Translator Gen II and see what the car can lay down”
    Sorry for the confusion.
    And if I’m wrong on anything, someone please correct me.
    I meant this one.
    FULL THROTTLE SPEED - MAF Translator Gen II
    But I think this is what I'll go with, anyone have any experience with it?
    SDSU Alumnus verified Feedback Score 4 (100%) bboyalan's Avatar
    Nov 2006
    Chula Vista SD, CA
    I agree with him since you already have the ingredients to make it happen, although the 450's are going to be spent rather quickly.
    The A'PEXi AFC NEO is really nice. Yours should work since I was able to tune a local VR-4 with the following firmware update:
    -sent from my G2
    4/1/21 - "retuned" est. 570AWHP VD SAE (580 U/C | second gear | 88F) holding ~30psi (more boost & less timing still... hehe)
  8. The Following User Says Thank You to bboyalan For This Useful Post:
  9. #8
    Ok, just had another thought on this. I would also need a wideband gauge to go with this correct? Or does the NEO have a gauge built into it? Please correct me if I wrong, but if I went with the GEN II I would also need to purchase a wideband gauge, but if I went with the NEO the gauge is in the conroller?
  10. #9
    Feedback Score 6 (100%)
    you are going to want a wideband either way. None of the piggybacks have wideband controllers in them.
  11. #10
    yea you def should install a wideband and a data logger if you don’t already have them.
