Page 1 of 5 123 ... LastLast
Results 1 to 10 of 42
Thread: Help me tune please!!!!
    So I finally got a logger for my car but now I don't know what to do from here. How do I read the narrow band in volts (I think that's what they are in) . I'm get like 14 counts of knock on some pulls then non on others. Also timing adavance like 58%. Is this all bad? I just need a lil guidance.
    Stealth owner since '91
    Sthrn NH/Eastern Ma
    Here's a couple of links I found helpful when I got my logger:
    TMO Datalogger 101
    Stealth 316 - TMO Tech
    It's a bit of an art interpreting the data but these should get you started.
  3. The Following User Says Thank You to Steve '92ES For This Useful Post:
  4. #3
    wheatfield, IN
    upload your logs, and we can look at them and try and help you. what do you have for "tuning"? the logger just lets you see what is going on, it doesn't let you "change things"
  5. #4
    Quote Originally Posted by dpartinvr4 View Post
    I have a safc yea I will try to get the logs up here asap. My car is lean missfiring in-between shifts and the logger logged about 28 counts of knock at about 6 degrees advtiming.let me get the logs up here so you can take a look for yourself. Do I have to have Microsoft excel to extract the logs? Also just so you know I'm a atx running on a NA ecu.
  6. #5
    wheatfield, IN
    excel would probably work best, my HHH has an export option that just shoots everything to excel.
  7. #6
    Does HHH Work on plams?
  8. #7
    wheatfield, IN
    Hand Held Halo is my logging software, I was just saying, exporting to Excel is an option mine has, yours will probably have something similar.
  9. #8
    Yea I thought hand held halo was PC only.
  10. #9
    Could my bov Be messing with my readings cause I'm getting alot of knock and back fire during shifts. Damn this NA ecu.lol. Also the tps on my logger is at 14% at idel and goes to like 96% but my afc. Goes across the band. I'm going to try and get a video untill I can upload these logs.
  11. #10
    What injectors are you using?
