I ordered a new IAC/ISC valve from rockauto, my stock one looks like it shorted out near some of the pins. Before I put in the IAC, I want to double check that my grounds are okay so the same thing doesn't happen to the new part. I also have the issue where my lights go dim at idle.
I looked in the service manual for grounding locations, but the section where they show the locations does not include the ground strap from the plenum to the firewall nor the ground strap that is on the radiator bracket. Can anyone tell me where all the ground straps are?![]()
