The machine integrates the peaks so that you get a relative quantity measurement between them. The calculation is a little tricky because a molecule of ethanol is much lighter than a molecule of gasoline (octane) but it also has fewer hydrogens. Ethanol has a molecular weight of about 46 and has 6 hydrogens and octane has a molecular weight of about 114 and has 18 hydrogens. If I ignore everything else, the machine is showing that the 6 hydrogens of ethanol account for about 93.5% of the area and the 18 hydrogens of gasoline account for 6.5% of the area. So from there is is easy to calculate the mole %. First of all, since there are 3X as many protons in gasoline, the 6.5 area % is 3X its mole %, so that would be only 2.17 mole %. But, since gasoline weighs 2.48X more than ethanol, that pushes it up to 5.4 weight %, or about E95.
There is an obvious problem with that, though, and that is that I don't know what all the mystery peaks are. They aren't calling it E85 because it is 85% ethanol and 15% gasoline necessarily. Perhaps it is 85% ethanol, 5% gasoline, and a 10% mixture of other crap. Or, some of the gasoline protons could be buried underneath ethanol peak C and I'm counting them as ethanol when they are really gasoline. Anyway, here is a higher resolution picture of the NMR:
