To calculate λ, simply divide the actual AFR by the Stoichiometric AFR.
Narrowband sensors can only measure the presence of oxygen in the exhaust, so can only correctly show if the system in lean, with excess oxygen passing through the exhaust. Once the system is rich, there is little or no free oxygen left, so exactly how rich can't be determined.
When working correctly in open loop which is a default rich condition, the ECU runs a self learned program subject to the long term fuel trims available in OBD2.
