Results 1 to 10 of 18
Thread: Gas in my oil??
    Gas in my oil??
    Ok I have a 92 vr4 and I think im going crazy but I smell gas on my dip stick,what should I do?
    Canaan NH
    That would usually be caused by a leaky injector. How does it run ? Rough at start up ? Black smoke when you first start it ?
    You either have ring issues, or are running way too rich. You have aftermarket injectors?
    Ex 3SI Super Mod verified
    Agreed, do you have any way to control air/fuel?
    Haha, we really need to fix the smilies. I keep doing exactly what you are and using the old smilie code.
    Ha! I guess you saw the before I changed it lol Next order of business, FIX THE SMILIES!!!!!!!!!!!!!!!!
    Yeah. I obviously knew what you meant. I did it to someone earlier myself.
    Car runs strong,cant tell if any black smoke cause I think my vss are bad and I burn oil.
    Did check all my piston rings and they all held perfect,I think I run rich,injectors are stock and I have 121,000miles.
    Quote Originally Posted by Tool Man View Post
    I dont have one but when I had my wideband hooked up I would run rich of the charts at WOT,most people told me our cars stock run rich .
    Low & Slow verified
    Fortson, GA
    First, get that gas filled oil out of the crank case. Then worry about what is causing it.
    Jeff
    Quote Originally Posted by kywhitelightning View Post
    Jeff
    Done.
