Actually I do have a missfire/popping noise at idle but compression was like 132-142 and leakdown test was perfect.
Have you checked your mechanical timing? Popping may come from the engine being out of time. Compression is also a bit low, not out of spec but low.
Jeff
115 is the lower limit and no greater than a 14 psi difference between cylinders. 156 is the upper number.
I was thinking the lower limit was 125 when I typed the other message.
Thats on a VR4. On a DOHC upper limit is marked as something like 180 per the manual, but most people see 210. I to this day think its a typo. SOHC's upper limit is 172 with a lower limit value of 124 IIRC.
Just a FYI, black smoke = Fuel, Blue = Oil, White = coolant.
