Results 11 to 20 of 46
Thread: The Monthly "My Car is Running Bad" Thread
    Bump. I would really like someone's opinion of the timing in particular.
    Just an update for anyone who might be wondering what the issue was, the ECU was sent off to AvPro and has been running great ever since.
    Well, she's back. Unfortunately worse than before and I'm almost positive it's a problem with the ECU, ARC-2, or 91-92 style CAS.
    I'll be ripping everything apart in the next couple days, wish me luck.
    im having problems as well mines a 94 tho i havent heard ever of an ecu in 94+ car go bad but its identical to the ecu problems i had in my 92. i too am also running thee arc2 92mm big maf car idles revs ect but try to move the car and it backfires/afterfires like crazy just 1 loud bang
    curious as to what you find im up for trying anything. havent drivin the car almost at all this yr
    Newark, DE
    Same issues as before? No revving past 3000rpms and no idle? Last time she wouldn't hold idle for me it was the MAS, got a used one from GZP and resolved issue. There is also a vendor in MD that replaces caps on ECS and ECU...I don't readily see them as a vendor anywhere...
    91 AWD TT
    As of now the car will barely hold 1500rpm, will slowly bog itself to death.
    vyper1 you sound like you have the same issue here. In my case, this problem only occurs during the colder months.
    Newark, DE
    I had these guys do my ECU and ECS Auto Velocity |. It was a bit ago, and IIRC it seemed longer than I wanted it to be, but I am happy with the job.
    You sound like you are already trouble shooting using the Fuel section of the manual, I would continue to do that; ensuring you have fuel, spark and air. You are getting it all to some degree.
    If you are confident your ECU is okay, my next step would be sensors, I would trade your MAS out with a known good one, also its temperature related/sensitive.
  8. #18
    Twin Turbo verified
    Melbourne, Australia
    Unplug your MAF and see if it will rev.
    Waiting install
    Build Thread
  9. #19
    Granatelli MAS doesn't have baro, iat, or any of that jazz. The arc2 itself sends out a 68F and 1bar signal to the ECU, which is a fixed value that doesn't change. I am 0% confident in the ECU rebuild, but I'm not counting on it being the problem.
  10. #20
    Son of a bitch, looks fine.
