Here is my intake setup for no maf (could be used for blow through)
$10 4" silicon joiner: Turbo Piping
$15 ebay AEM 9" x4" dry flow filter.
It may not look like it, but that is pretty much the biggest filter I can fit. The silicon joiner BARELY fits in the stock bubble piece. I ovaled the maf side out a bit just by squeezing with my vice, but it is still a very tight fit. The pics do not do the filter justice, it is huge.
FYI, if you are just starting tuning with the emanage ultimate in speed density do not run the a/f target map for cells at idle and around idle. The emu will adjust way to fast and you won't be able to keep the car running.
